Old 06-11-2009, 08:49 PM
nydxa's Avatar
Default Butel 996 Software Question
I'm wondering if someone can verify an idea someone suggested. I'm in New Jersey where the State police have three primary systems. In the Northern part of the state Troop B is used. Central New Jersey is served by Troop C. Rather than programming these in as two separate systems, I've been told I can program the individual frequencies for both systems into one bank. In doing so, as I travel within the coverage area of each system, the 996 would lock onto the appropriate system. The TG list would contain TG's for both systems. Will this work?
Thanks!
In the NYC metro area?
Join our weekly Scanner net, Wednesdays at 9:00 p.m. on the 441.100/145.230 repeaters.
Visit us at www.nydxa.info
Old 06-11-2009, 10:19 PM
thewenk's Avatar
Thanks!
If I understand correctly what you are asking, I don't think it will work. Each site needs to be programmed separately to work correctly. You might want to look at this thread for a better explanation.
http://www.radioreference.com/forums...ite-works.html
Dave
BCD996T, BCD396XT, PSR-600, PRO-106
DPD Omni-X Multi Band Antenna
DPD 700-1000 MHz LP Antenna
TinLee Diplexer
Old 06-12-2009, 03:21 AM
ac7xc's Avatar
Send a message via AIM to ac7xc Send a message via Yahoo to ac7xc
Exclamation
Thanks!
It will work IF The two systems can not be heard by the bcd996t at the same time. If this is a automobile station I would not do it because as you travel around you are likely to have areas where you can hear and decode both control channels and the radio will lock onto one control channel then exit that group and then lock onto the next control channel.
If the control channels are very far apart, a 150 miles or so it should work fine, but if they can be heard at the same time by the BCD996T do not attempt because you will miss transmissions due to the fact the bcd996t is going to lock on to either one of the control channels.
HTH,
____________________
Best Regards, Keith http://home.comcast.net/~kilowattradio/
BCT15X PRO-106 PRO-92 Pro-83 TH-F6A FT897D BC346XT BC245XLT
Mac OS X, Vista 32 & Linux
Old 06-12-2009, 05:30 PM
nydxa's Avatar
Default Thanks
Ya, so in this case I can't hear Troop C while in my home area served by Troop B. I'm wondering if I can program in B and C as separate sites, as in the Morris County system. Definitely some things to try this weekend.. thanks!
Similar Threads
Butel 996 Software ARCPRO donnyelms Scanner Programming Software 3 12-16-2008 12:41 PM
What happened to V3 Butel software for 996? nydxa Uniden Scanners 3 12-02-2008 10:09 PM
396T Software Question motorman105 Scanner Programming Software 8 12-29-2007 04:53 PM
Multi-State Statewide Question (996 Uniden Scanner) bReed11091 Uniden Scanners 0 02-01-2007 05:41 PM
BuTel software release first free software for Uniden BR330T! Butelsoftware Scanner Programming Software 0 11-03-2005 08:41 AM
