Old 06-17-2009, 12:39 PM
Default help with win 93
I have a RS pro 93 and just got a GRE usb cable for that model that seems to do the connection. my problem is opening the win93 program. explorer keeps flashing and I have to ctrl-alt-delete to get out of it
this is a vista and Ive tried the open zip and winxx. is there a virus or am I the dummy?
Old 07-30-2009, 12:11 AM
Send a message via AIM to whitesox4life Send a message via Yahoo to whitesox4life
Wirelessly posted (LGE-VX9100/1.0 UP.Browser/6.2.3.2 (GUI) MMP/2.0)
I dont know about with vista. I downloaded 92 93 and 95 along with freescan to my flash drive and copied the unzipped files to my hard drive. That may work with vista. I run xp.
1RWN: IN12
Shack: Realistic Pro-52, Bearcat 155, Kenwood TK-270G, /\/\ Minitor IV
Old 07-30-2009, 02:54 AM
gmclam's Avatar
Smile
I am running all of the WIN9x programs under NT & XP with no problems. I also have both kinds of cables. One problem many people have is to make sure the (correct) driver is loaded for the USB cable. BEFORE running WIN93, I'd plug in the USB cable, then go to CONTROL PANEL > System > Hardware > Device Manager > Ports to see if your cable is listed (it will tell you what COM port has been assigned). If you do not see the cable, you need to load the driver. I've been able to find the driver from the Radio Shack web site (just search for the cable part number and it leads you to it).
Now if your cable & driver are working correctly, and the program "crashes" (or causes things to crash), then the next thing that comes to mind is making sure you have the correct DLL file. I remember way back having to download the correct DLL file separately. Check info at www.starrsoft.com if that's the case.
If you get WIN93 to run, make sure to set the COM port to the value you saw in the control panel above before you try to talk to the scanner. Good luck.
PRO-95 | (customized) PRO-10 | PRO-97 | PRO-77 (customized) | PRO-92 | PSR-300
Similar Threads
PRO 96 / Win 96 Programming Help rqueen2229 Radio Shack Scanners 33 04-11-2009 06:47 PM
Win 5oo and Win 5oo Remote Client Question... btritch Scanner Programming Software 2 08-04-2008 04:56 PM
Win 500 % Win 500 Remote Server Access btritch Scanner Programming Software 0 07-16-2008 09:00 PM
Question About Loading V Folders Into win 500 btritch GRE Scanners 5 06-18-2008 07:59 PM
WIn 95& Win 96 Question bb49490 Scanner Programming Software 5 03-26-2008 05:46 PM
