Old 06-18-2009, 09:35 PM
nydxa's Avatar
Default Butel 996 Question / Possible Bug
So this issue starts when I asked myself if the 996 could do dual mode receive in one channel (analog w/ PL or DPL and P25) by setting the audio type to ALL.
If I program in a frequency and designate a PL / DPL, than set the audio to ALL - I can save these settings by pressing SAVE.
However, if I use "SAVE ALL SYSTEMS", "ALL" changes to "Analog" audio if a PL / DPL was specified.
Shouldn't SAVE and SAVE ALL SYSTEMS work the same?
In the NYC metro area?
Join our weekly Scanner net, Wednesdays at 9:00 p.m. on the 441.100/145.230 repeaters.
Visit us at www.nydxa.info
Old 06-18-2009, 10:59 PM
datainmotion's Avatar
If I'm understanding your question correctly, the answer is no.
The reason it is switching to "Analog" is that you have a PL set. Lose the PL and it should stay "All". PL/DPL is not compatible with any setting which may include Digital such as "All"
I believe "save profile" and "save all systems" will correct any disparities in your settings when saving, which is what you are seeing.
Denver International Airport - Public Safety Online Scanner
Travelling to or through Colorado? Click here
Old 06-19-2009, 08:19 AM
nydxa's Avatar
Default Sorry I was not clear enough
I think you missed the possible bug...
"If" I click "SAVE" it indeed saves the PL and the "ALL" audio setting.
If you click "SAVE ALL" (open systems) it changes the "ALL" <audio setting> to analog.
Why should two different SAVE commands, save files in two different ways?
Also, while the 996 is not a Motorola radio, I have two that can do dual mode receive by simply designating the PL/DPL in addition to analog and digital mode. Within the logic when it detects digital P25 it ignores the PL / DPL.
My concern is not with how the radio works, but with "why does the 996 software save files differently depending on if you use SAVE or SAVE ALL?
Old 06-19-2009, 09:15 AM
Not Posting
Ask Butel??
Similar Threads
996 question help frank125 Uniden Scanners 2 11-27-2007 08:02 PM
996 question jrs71 Uniden Scanners 2 07-14-2006 10:15 PM
996 question for owners les108 Indiana Radio Discussion Forum 1 07-13-2006 10:44 PM
?s re: Setting Up 996 & Reviewing Locked Out Freqs jimlawrence Uniden Scanners 0 07-09-2006 09:04 AM
996 Question Re USAD Software Using BOBRR Uniden Scanners 0 07-02-2006 10:30 AM
