Old 06-19-2009, 07:36 AM
slvbeard's Avatar
Default Belkin USB to Serial and ARC396 Problems
Anybody have a problem with using a Belkin USB to serial converter and ARC396 software? Every time I try to read the scanner with ARC396, the computer reboots. I've reloaded the computer, loaded new drivers, etc. When I use a Sabrent USB to serial, everything is fine. Just wondered if anyone else has encountered problems with the Belkin USB to serial converters?
Old 06-19-2009, 07:52 AM
slvbeard's Avatar
I think I got it working now, changed COM ports.
Old 06-19-2009, 08:41 AM
ac7xc's Avatar
Send a message via AIM to ac7xc Send a message via Yahoo to ac7xc
Arrow
Do you have sync software running for an iPOD, Cell/iPhone, Blackberry or camera on your computer? That is the number one thing to check when you start having problems with serial ports. Often the devices will have programs that monitor the comports for a connection from a device. In windows go to the Start menu, select run type
msconfig
in the box and press the enter key. Go to Startup section in msconfig to see a list of available programs that are run when you boot or login to your computer.
____________________
Best Regards, Keith http://home.comcast.net/~kilowattradio/
BCT15X PRO-106 PRO-92 Pro-83 TH-F6A FT897D BC346XT BC245XLT
Mac OS X, Vista 32 & Linux
Old 06-19-2009, 09:25 AM
slvbeard's Avatar
Itunes software and also Microsoft Active Sync may have been the problem. Seems to be working now on COM2.
Tags
butel arc396 belkin
Similar Threads
FS: BIG Uniden BCD396T Package (ARC396 + USB Cable + Diamond RH77CA Antenna + MAX-800 Ant Fast_Draw Old Classifieds Archives 1 01-25-2009 08:07 AM
