Old 06-22-2009, 09:47 AM
DamnDirtyApe's Avatar
Default Freescan 9B 'Citical Error 9 w/ Illinois Starcom21 files
Using 9B of Freescan and importing the 'south' programming file and getting 'critical error 9, unable to continue' and think I might not be loading all the sites in the file. Under Vista SP2 with the BCD396XT.
Help would be appreciated, thanks
______________
Uniden BCD396XT
GRE PSR-300
Uniden BC278CLT
Old 06-22-2009, 03:57 PM
cpuerror's Avatar
Are you importing a .996 file? If so, try using the File*Open function to load it.
http://scannow.org - Download FreeSCAN
Old 06-22-2009, 04:17 PM
Hi
I had problems with File/Open in that it warned me it was a format belonging to ARC, and would not open. I contacted the author of the SC21 files and was told to do the 'import' which does indeed load, but is causing an error or experiencing the Critical 9 message and does not load completely.
______________
Uniden BCD396XT
GRE PSR-300
Uniden BC278CLT
Old 06-22-2009, 05:13 PM
cpuerror's Avatar
Would you mind posting that file here?
Old 06-22-2009, 05:39 PM
http://www.carmachicago.com/profiles...om%20Files.zip
______________
Uniden BCD396XT
GRE PSR-300
Uniden BC278CLT
Old 06-23-2009, 01:32 AM
any luck cpuerror?
______________
Uniden BCD396XT
GRE PSR-300
Uniden BC278CLT
Old 06-23-2009, 06:07 AM
cpuerror's Avatar
Oh yeah next version will fix this. I didn't take a really close look but it looks like the UASD files in that zip contain the same information, so you might be able to get by with those.
Old 06-23-2009, 06:14 AM
Wiki Admin
Yeah the PDF file says as much. DamnDirty, I tried all 3 UASD files and they imported fine - however, I did get a message that the number of talkgroups is too high. Undoubtedly some surgery is necessary.
73 Mike
Old 06-23-2009, 10:10 AM
thanks for checking, I managed to get the XT so I don't think the new UASD is out yet. I would have thought the files would have been ready to go format, but I'll keep an eye on them. Thanks!
73 Mike
______________
Uniden BCD396XT
GRE PSR-300
Uniden BC278CLT
Old 06-23-2009, 10:11 AM
for the next version as to any idea when?
______________
Uniden BCD396XT
GRE PSR-300
Uniden BC278CLT
Old 06-23-2009, 11:48 AM
cpuerror's Avatar
It's hard to say, maybe 1-2 weeks. Theres still some things that I want to do before getting this new version out.
Old 06-23-2009, 01:42 PM
DamnDirtyApe,
The usd files that are in that zip seem to import just fine into FreeScan for me. Have you tried those?
You don't need the new USAD to import them into FreeScan.
Dick
WD9GRI
Milwaukee, WI
Old 06-23-2009, 08:53 PM
Wiki Admin
I said the same thing earlier in this thread about the .usd files importing OK (although there are too many talkgroups...)
From all indications, it seems that the UASD for the XT scanners isn't coming out anytime soon, if at all. I think Assaf, Bob and Gommert have knocked the developers - whoever they are - out of the park on this one....73 Mike
Old 06-23-2009, 10:55 PM
cpuerror's Avatar
I really don't see why anyone even wants UASD when there are several better alternatives to choose from.
Last edited by cpuerror; 06-23-2009 at 10:58 PM.. Reason: Probably shouldn't go off with rants
Old 06-24-2009, 01:36 PM
Originally Posted by rvictor View Post
DamnDirtyApe,
Dick
Hey there - thanks for the tip! I see the USD does import into freescan.. I was thinking you meant UASD for the XT (which isnt out yet), but I didn't catch about getting them (USD) into freescan. Looks like they all import correctly.
thanks!
______________
Uniden BCD396XT
GRE PSR-300
Uniden BC278CLT
Similar Threads
StarCom21 Programming Files updated N9JIG Illinois Radio Discussion Forum 1 06-19-2009 11:32 PM
New StarCom21 Files for ARC and UASD 996 N9JIG Illinois Radio Discussion Forum 0 03-09-2008 08:06 PM
996 StarCom21 files for download N9JIG Illinois Radio Discussion Forum 0 10-16-2007 11:32 PM
StarCom21 Programming files available N9JIG Illinois Radio Discussion Forum 0 11-24-2006 12:53 AM
.usd files for Illinois? timkilbride Illinois Radio Discussion Forum 2 07-09-2006 04:00 PM
