Old 06-22-2009, 11:13 PM
Default Alpha Numeric Paging to E-mail
Does anyone know of a device that can read messages from alpha numeric pagers and convert them to an e-mail?
David
Old 06-23-2009, 10:25 AM
DaveNF2G's Avatar
A program called WinFlex had such a feature. It has not been supported in a long time and I'm not sure where it can be found any more.
David T. Stark, NF2G
Educator - Criminal Justice, Sociology
NF2G's Forensic Scannist Pages http://nf2g.com/scannist
Don't run from the police. Motorola always beats Mopar!
Old 06-23-2009, 02:32 PM
Thanks for you reply, that helped me come upon a program that is supported, PDW! I am still learning how paging systems work,but I pick up on things really quickly. On the back of my pager it lists Baud as 1200, freq: 152.48. Could someone point me towards some articles that can explain how all this works so I can start to try and configure PDW.
Thanks,
David
Old 06-23-2009, 07:53 PM
DaveNF2G's Avatar
PDW doesn't require much configuring. The soundcard processes the audio, although you need a discriminator tapped receiver to get clean enough data for decoding. The software pretty much identifies the paging format used by itself.
Old 06-23-2009, 10:08 PM
For initial testing could I just pipe it directly out of the scanner? Anyone have a cheap scanner they want to sell me?
David
Old 06-24-2009, 01:23 AM
David
Depends on what paging Protocol is being used. If it is Pocsag, then you can ceratinly use Speaker/Earphone audio. Numerous people in my area use PDW, using only Speaker/Earphone audio, to monitor the local Pocsag pagers (the Emergency Services (Public Safety) use them a lot). If your network is using Flex, then I can't help.
Bitrates (Baud) for Pocsag are: 512, 1200, are 2400, and in PDW you can elect to monitor all bitrates at the same time, although we have never seen any 2400 on our local systems.
Obviously, 152.48 is the frequency you need to program into your scanner.
Be Warned: PDW is VERY sensitive to the setting of the Volume level. A "cat's wisker" either way, can mean the diffference between Decoding and NOT decoding.
Also, these two links might be of some use.
http://a23.video2.blip.tv/2510001217...erPart1238.m4v which is 72 Megs, and
http://a11.video2.blip.tv/1070001263...Scanner869.m4v which is 26 Megs.
Basically they show how to put a Discriminator Tap on a Pager.
Comint
Last edited by Comint; 06-24-2009 at 02:06 AM.. Reason: Added Links, and corrected a typo.
Old 06-24-2009, 10:15 AM
DaveNF2G's Avatar
The 512 bitrate is usually numeric pages only. Text pages are at 1200 and up, and I agree that 2400 seems to be rare.
Similar Threads
Charlotte Alpha Paging yardbird North Carolina Radio Discussion Forum 2 05-06-2008 05:08 PM
Alpha Numeric scanners RTrue General Scanning Forum 2 02-20-2008 05:53 PM
Alpha & Numeric Characters DocDaddy Uniden Scanners 7 09-28-2007 04:33 PM
396 TGID Alpha / Numeric Toggle? avistow Uniden Scanners 3 11-27-2005 09:24 PM
The Wonderful World of Pagers Radiorick Tavern Archives 17 01-28-2005 06:30 PM
