Old 06-27-2009, 10:06 PM
Default Entering a frequency manually into Win500
How do you enter a frequency manually in to win500? I have not been able to figure out how to do this. Is there a users guide that is available?
thanks for any info
Old 06-27-2009, 10:51 PM
Right-click and Insert Item
Old 06-27-2009, 10:55 PM
Then after it inserts how do you edit?
Thanks for your help
Old 06-27-2009, 11:02 PM
Just click on the fields in the object, and type. I have found that sometimes there's a delay between when you insert a new record, and when you can edit it, depending on how big the file is.
Lots of radios, not enough antennas...
Old 06-27-2009, 11:08 PM
Thanks very much for everyones help.
Old 06-28-2009, 01:57 AM
qlajlu's Avatar
thanks for any info
There is an illustrated help file here that should answer most of your questions as you are starting out with WIN500.
Illustrated instructions for entering individual conventional frequencies is here.
If you can read this, thank a teacher - If you are reading it in English, thank a veteran.
Drive no faster than your guardian angel can fly.
Time has a way to corrupt everything.
Similar Threads
Brunswick County shp08 North Carolina Radio Discussion Forum 434 10-24-2008 12:34 PM
Input Frequencies kevin390 New York Radio Discussion Forum 1 10-21-2007 01:01 PM
Entering a single frequency in BCD396T jeffreys48 Uniden Scanners 5 05-22-2006 12:20 AM
combining antennas scannerdweeb General Scanning Forum 22 05-09-2006 02:59 AM
Got this from my Union page might be of intrest to someone!! Stumper426 General Scanning Forum 1 06-22-2004 08:49 PM
