Old 07-05-2009, 12:59 AM
Default ARC780 v1.17
Ok been using this thing for years on 4 diff 780's, today go to open it and I get small window not opening program ()Attemp to Acess Invalid Adress () mem.780.exe (was used ok the other day)
I have tried everything I know , uninstall program 10 times now, re-install at least that many, downloaded from butel site,
re-booted my computer
defragged hard drive,
disk cleanup,
free utility call advanced disk cleaner
run a program called system mechanic (to keep pc running smoothly ?)
I am ready to jump off a bridge
WTF am I missing ?
Any suggestion , I am always tweaking my units ,adding new freq's etc.
Old 07-05-2009, 09:56 AM
Bill_White's Avatar
Try version 1.18
Software for Uniden Radioshack GRE GRECOM AOR police scanner software PRO-97 PRO-96 PRO-2096 PRO-106 PRO-197 PRO-164 PRO-160 PRO-162 psr500 psr600 psr300 psr400 psr100 psr200 BCD996T BCT15 BC246T UBC800XLT UBC785XLT PRO-433 PRO-528 BCD396T PRO-2051 P
There is no dark side of the moon really, matter of fact, it's all dark.
Old 07-05-2009, 10:04 AM
Wiki Admin
Or, even better (and better supported, too, since ARC780 hasn't been updated in quite a while, I'm sure) go get ProScan, which supports the 780
73 Mike
Similar Threads
arc780 Chear Sheet needed CVPI4Ever Scanner Programming Software 21 02-09-2009 11:59 AM
ARC780 - Any PDF ? slypx Scanner Programming Software 0 01-20-2008 01:48 PM
ARC780 to Attach with the RR Database??? rsrash Scanner Programming Software 1 04-11-2007 05:28 AM
Need background image (ARC780) datainmotion Scanner Programming Software 2 05-15-2006 12:32 AM
Vegas Area Frequency File (ARC780 format) slarsenia Nevada Radio Discussion Forum 0 09-03-2004 07:47 PM
