Old 07-11-2009, 12:54 PM
Randall's Avatar
Default pro 197 programming software
which software is compatible with RR and easy to use? i dont care about all the features but i need to download my local starcom 21 system info into two pro 197's my dad just bought.Any help would be greatly apprieciated.
Old 07-11-2009, 01:31 PM
Wiki Admin
The big 3 are ARC500, PSRedit500 and Win500 - all linked from this page, and all 3 of these are web service compatible...
Object Oriented Scanner Software - The RadioReference Wiki
I don't own the object oriented scanners, so I'll leave it to others to comment on 'ease of use'. You might even be better off going to the Missouri forum and asking for files - and if you do, be sure to specify which software you are using. 73 Mike
Old 07-11-2009, 07:33 PM
poppafred's Avatar
I personally have Win500 and the programming cable from Radio Shack for my Pro-197 and could not have programed the scanner without them.
Fred - KK5AA
Pro 2004 x2 -- Pro 91 -- Pro 97 -- Pro 197
Icom IC-7000 -- Kenwood TM-V708a -- Yeasu FT-60R
Old 07-29-2009, 02:17 PM
Default can someone help
ok i have a Pro 197 and i have the Scancat-lite program with the mr scanner 2009 public saftey
i put all the frequencies from that on my scanner yet i still can not pick up any fire or police in my area
Can someone please help!
Old 07-29-2009, 04:24 PM
mikey60's Avatar
My suggestion in this instance would be to reset the global data to defaults and see if that resolves the issue.
There's three ways to do this. (Before doing any of these, I suggest making a backup of your config to a V-Scanner)
Option 1: Software
I know that my PSREdit500 can reset all of the global settings to default, and I'm sure that WIN500 can as well... I don't know about the others.
Option 2: Reset individual settings:
Press PGM, FUNC, F3 to get into the Expert settings menu.
For each menu option, press the F3 (Dflt) option.
This will reset the expert settings to their defaults without losing any custom settings like LED colors, WX SAME settings, Scanlist names and Welcome Text.
Option 3: Full GLOB reset
Turn the scanner off
Turn the scanner on
While the Welcome Text is on the screen, press the number 0, then the number 2, and then the ENT key.
This will reset the GLOB EEPROM to defaults.
Note: you will lose any custom settings you may have set, including Weather settings, LED colors, Scanlist names, and Welcome text.
http://www.psredit.com
Old 07-31-2009, 06:54 PM
What about the reband for the Tulsa 800 system? will I need a new scanner? I have a Radio Shack 2055.
Old 07-31-2009, 07:01 PM
mikey60's Avatar
Looks like most sites will be ok, but a couple won't once the reband is complete. The Tulsa site should be ok though.
Old 08-11-2009, 12:56 PM
Default please help
I am trying to program a pro 197. I have Win500 software with pro 96 freq. set in it when i try to transfer it says it is writitng data but nothing is happening. Do I need to up date it and if so how?
Old 08-11-2009, 10:38 PM
firetaz834's Avatar
I don't know if this is the answer, but I had something simular happen when I using a different programming software and a PSR-400. I would try to program the scanner and it said that the data was being transferred and when it was complete it said to remove the cable, but nothing was transferred. I discovered that the usb drivers were not loaded on my computer. Once, I reloaded the usb drivers, then everything worked normally. Just a suggestion.
Old 08-11-2009, 11:11 PM
You need to check & make sure the program comport is set to the same 1 as windows shows the cable on.
Paul.......do as lasmith43 says
Old 08-12-2009, 01:29 AM
poppafred's Avatar
And make double sure you have the new drivers Paul lists on his web site for the cable.
Fred - KK5AA
Old 08-12-2009, 08:49 AM
who's website???, UPMAN has a website???
Old 08-12-2009, 05:51 PM
poppafred's Avatar
My bad.
Don, as in Don Starr with starrsoft.com and Win500.
Fred - KK5AA
Similar Threads
programming software scanner99 Uniden Scanners 5 12-27-2008 01:50 PM
Pro 96 original programming file needed rdaufan Radio Shack Scanners 1 10-29-2008 10:07 PM
Are you looking for free programming software? wayne_h Motorola Forum 1 08-21-2007 10:42 PM
Best software for the pro 97 lanke Radio Shack Scanners 17 06-09-2007 11:58 AM
Extended Online Control BCD396T UASD Programming Software josephdavis13 Uniden Scanners 1 04-22-2006 10:00 PM
