Originally Posted by Butelsoftware
I will add the option to import by profile in a next release but in general the batch import should do the trick when importing multiple files, just drag the files into one folder and the select that folder for import.
Gommert
Butel Software
Thanks. I did that, but of course it's more labor intensive and I'm just trying to find the lazy way out!
Also, at one point I asked about a Start Up Key Overview feature for ARC996. That would be very helpful when trying to set up multiple start up configurations.
Of course it would also be helpful if Uniden designed the firmware so that a system could be placed into multiple start up configurations. Sort of like GRE did with the Object Oriented scanners in allowing frequencies and talk groups to be associated with multiple lists.
Which is not in any way something that you can deal with.
