Old 07-23-2009, 08:02 PM
Default win500 software programming
Is there a way to program win500 with several talksys to scan the same talkgroups without programming the same talkgroups for each talksys. Hope this isnt to confusing.
Old 07-23-2009, 08:10 PM
mobile1's Avatar
If all the systems are P25 you can put all the control channels together and then choose milti-site roam.
Trunk tracking Sask.Public Safety P25 system with Win500/PSR600C and Pro96com/PSR500C and trunk tracking FleetNet 800 EDAC system with BC250/BC780XLT. Scanning everything else with an Icom R10.
Old 07-24-2009, 05:33 PM
Default Win500 programming
Thanks mobile1 for the response. Yes it is a p25 system. The counties that I am monitoring are very large and have lots of talksystems. So what I did is broke the counties up into sections (4 total) and programmed 32 talksystems into each section according to there locality. Since I do not know what talkgroup uses what talksystem I programmed the same talkgroups into each talksystem which took up a lot of my scanner space. Does roam basically do the same thing? I did find that I am picking up a lot more talk after doing this. Did I do that right?
Old 07-24-2009, 05:45 PM
qlajlu's Avatar
foggymoon, what kind of scanner are you running?
If you can read this, thank a teacher - If you are reading it in English, thank a veteran.
Drive no faster than your guardian angel can fly.
Time has a way to corrupt everything.
Old 07-24-2009, 06:33 PM
I am using the RS 106
Old 07-24-2009, 07:49 PM
qlajlu's Avatar
You are probably talking about the WyoLink system which is P25, but isn't most of Wyoming still on VHF/UHF? I dunno...anyway...
Would you mind linking the system you have programmed? I get this feeling of overkill from the way you have described what you have done and a little confused. WyoLink covers the entire state and just scanning from Cheyenne you wouldn't need ALL of the sites programmed in. (128 frequencies for only 12 TGs seems a little odd to me)
By the way, what you are calling talk systems is actually trunking systems (TRS for short).
Here is an illustrated help file for using WIN500 to program your scanner. It may give you some ideas also.
Old 07-24-2009, 08:50 PM
Thanks for the help qlajlu
I should of been more specific as the counties I was monitoring. I am close enough to Colorado to monitor talkgroups down to Denver. That is why I have programmed my scanner that way.
Old 07-26-2009, 11:50 PM
Similar Threads
Motorola P1225; programming adapter/cable and software videobruce Motorola Forum 8 06-25-2009 10:43 PM
Programming software for Pro-433? techman65 General Scanning Forum 3 12-11-2007 11:25 AM
Need BCD396T Software Programming Advice hmnurse1 Scanner Programming Software 7 11-09-2007 08:20 PM
Extended Online Control BCD396T UASD Programming Software josephdavis13 Uniden Scanners 1 04-22-2006 10:00 PM
