Radio shack 2096 and arc96
Iam using R.S. 2096 and butel software ARC96. i have inputed freq manually and also by inputing them by software. i have done this twice. both times all 9 banks will show on scanner as to be scanned but one bank will hang up. like now its bank 2. if i hit the 2 on scanner and remove it from banks to be scanned scanner takes off correctly. i go back to software although i have not changed or done anything to settings for banks all look the same. if you are familiar with this and you can tell me how ill send the file and you can verify it. thanks andrew stoots loyall ky. KJ4KCM
