Nuuze, something else to look at here - I don't see any group key assignments for Fairfield cab, Suisuin police, fire, ems, Vallejo police, fire, ems or GG com center. Each of these need an assigned and active group key, just like you did with Solano sheriff. Keep in mind that group quick keys (GQKs) are unique to a system - so just because you have GQKs 1 and 2 for Solano trunk, that doesn't mean you couldn't assign those same numbered GQKs to another system.
Also most folks will tell you that setting a delay time of 2 will slow your scan down. There may well be times when you want to do this, but normally it's best to set this to zero.
73 Mike
