| Scanner Programming Software This is the place to discuss scanner programming and control software. |
07-29-2009, 02:35 AM
Veiny member
Freescan not letting me d/l conventional from RR
I'm not sure if this has been addressed on here, I tried looking for it but couldn't find it.
I can import trunked systems from RR using Freescan with no problem, but when I try to access conventional systems, it says "Subscription appears to be invalid or expired. Check your RR account and try again"
Anyone have any thoughts?
[Insert huge list of radios here, posted only to inflate my sense of self-worth and brag to my fellow members about what a cool guy I am]
07-29-2009, 08:07 AM
Depends on what version you are using?
07-29-2009, 08:44 AM
Veiny member
I'm using .9C, downloaded less than a week ago.
07-29-2009, 09:00 AM
It might not be picking up the subscription expiry date on your account correctly. When does it expire? Could be a bug somewhere.
07-29-2009, 09:04 AM
Veiny member
I'm a DB admin, so I guess whenever Lindsay gets mad at me
07-29-2009, 10:32 AM
I think the problem is that you don't have an expiry date on your sub, so it figures its expired and thats why its kicking you off. Not a bug, just a feature designed to stop freeloaders, j/k. Well for the next version I will look into preventing this, in the mean time maybe you can get Lindsay to put an expiry date on?
07-29-2009, 10:34 AM
Veiny member
I'll try, but just to reiterate, I can download Trunking systems just fine.
07-29-2009, 11:19 AM
Yeah sometime ago I disabled the check on trunking systems because of another issue.
07-30-2009, 06:36 PM
I'm having the same problem. Any ideas?
Thanks,
P
07-30-2009, 06:38 PM
Veiny member
Lindsay's stance is that he's not going to recode the site to fix the problem (I don't blame him), so I guess we're back to square one.
07-30-2009, 06:40 PM
Veiny member
... does that mean that anybody with an RR account (and not a premium account) can download Trunked radio information?
07-30-2009, 07:38 PM
Ok well I get .9D out soon then. To answer your question H, you still need to be an RR subscriber, but that check is put there to give you a more useful error message if your account runs out then just a general error message.
Pjomm, is it just conventional you are having trouble with?
07-30-2009, 08:29 PM
Problems accessing Conventional Database
Hi cpuerror,
I am only have problems with conventional downloads. I just up signed up today but the account clearly shows that I 360 days left.
I'm using a 396T and version 9C.
Regards,
Paul
VE3XPJ
07-30-2009, 08:46 PM
Wiki Admin
I used version .9c and had no issues at all. 73 Mike
07-30-2009, 08:56 PM
Originally Posted by pjomm
Hi cpuerror,
Regards,
Paul
VE3XPJ
So what exactly happens when you try to download?
07-30-2009, 10:35 PM
Hi cpuerror,
When I go in the menu, select import, radio reference conventional, then type type my username and password. After about 10 seconds this error appears:
Hope this helps,
P
07-30-2009, 11:28 PM
Hrmm, what is your subscription expiry date?
07-31-2009, 12:29 AM
Expiration Date Status
07-25-2010 Active
