Originally Posted by JBuff27
In WIN500 please take a look under the Tab "TSYS OBJECTS" at the Trunking Tables Column Headings,
at what I think is suppose to be "Lo." but does not look like it.
Thank you.
JBuff27
Yes, that is what it is supposed to say. Just put your cursor on the dividing line between that column and the column on the right labeled "Hi Chan" (until the cursor turns into a double-headed arrow) and pull the dividing line to the right. That will expand the viewing area of the column and the whole word will be visible.
If you can read this, thank a teacher - If you are reading it in English, thank a veteran.
Drive no faster than your guardian angel can fly.
Time has a way to corrupt everything.
