Old 08-01-2009, 07:28 PM
benca's Avatar
Angry ARC330 3.1 Problems
Has anyone made the ARC330 connectt o their radio with the usb-1 cable, (note radio and cable work fine with BCtool), so I know its the 3.1 version of ARC330.
Ben
Old 08-01-2009, 07:44 PM
Ben
Affirmative !!!
I have Arc 433, Arc 396 and Arc 996.
I experienced the same problem and more. Screens not showing right, boxes not adjustable so you can only see part of the text - etc.etc.
Went back to the older versions and everything worked right.
But can't use them now because they won't access the database.
I've downloaded several times just to make sure no errors on download and that I had the right versions.
Now I'm screwed until something gets fixed.
Ken
Old 08-02-2009, 07:58 AM
Same here, old version &sb1 work fine, but no database. I also have a BCT-15, downloaded new version, same computer, same sb1, and it works fine. It's gotta be a problem with the new version.
Old 08-02-2009, 12:55 PM
Same problem here also loss old data on systems that were stored in memory!
Old 08-04-2009, 09:42 PM
Question
Has anyone got the software update to work yet? Have reloaded twice with the same problems>
Similar Threads
state radio problems? dougbaker Colorado Incidents and Breaking News 48 12-30-2006 07:54 PM
996 Problems & Faults bReed11091 Uniden Scanners 34 10-25-2006 07:13 PM
396T Antenna/Connector Problems MysticalOS Uniden Scanners 16 07-25-2006 02:01 AM
MTrunker and Windows 2000 Problems? Forts Trunking Control Channel Decoding 2 04-09-2006 08:01 AM
396D problems hank1944 Uniden Scanners 95 03-14-2006 08:34 PM
