| Scanner Programming Software This is the place to discuss scanner programming and control software. |
08-01-2009, 06:04 PM
arc500 program
i go to trunk on arc500 and it says at bottom radioref disconeted wating retrieving http data ever time what can i do
08-02-2009, 01:02 PM
There doesn't appear to be anything that you can do except read the other threads and wait for a new version of the software to be released.
Dick
WD9GRI
Milwaukee, WI
08-02-2009, 01:59 PM
thanks anyway
my porb is i have 3 pro-106 that need programed !!!!!!!!!! they will just half to wait
08-02-2009, 02:45 PM
You could always use the WIN500 30-day free ride to do the programming until your ARC software is updated. Maybe unethical, but it could be done.
If you can read this, thank a teacher - If you are reading it in English, thank a veteran.
Drive no faster than your guardian angel can fly.
Time has a way to corrupt everything.
08-02-2009, 03:06 PM
yea win500 is hard the arc500 is easy win it works!!!!!!!!!!but i will try win500 again
08-02-2009, 03:19 PM
I've never used ARC so I cannot argue that with you. I have, however, used WIN500 for a year now and have not had problems, so speak of, and DonS, the author, does not go on vacation!
Anyway, I've written an illustrated, step-by-step help file that may make it somewhat easier.
08-02-2009, 06:07 PM
Thank you very helpful!!!!!!!!!!!!!!
JEFF ALTICE Roanoke ,Va LIVE AUDIO
08-02-2009, 06:15 PM
Thank you. However, let me point out that regardless of what software you use to program you scanner, you will NOT be able to import any information from the Database without a Premium Subscription.
08-03-2009, 01:39 PM
i am premium sub
i am premium subscriber and i have live audio roanoke va check it out if u have time!
08-03-2009, 06:08 PM
thank you veryyyyy helpful!!!!
the arc is a little easier! but with your help i was able to use win500 . was not so hard after all . thank you thank you if you ever need anything email me at alticefamily@aol.com
08-03-2009, 07:04 PM
Also Jeff, A few weeks ago I ask ARC500 to do something about his Reband Calculator. When used as designed, it recalculated frequencies for all 18 TSYS in my file. Including VHF, UHF, 385, 764 and 900 trunking systems. The calculator provided no method for which TSYS to recalculate. Due to incorrect data this makes it impossible to send a profile to the scanner. Thus useless software until the problem is fixed. Win500 and PSREdit both have reband calculations set by each TSYS.
BTW, it took 5 days for his reply to the issue, but stated he will fix the problem on July 10. Guess he went on vacation for both issues.
Frank
RR Wiki Programming Shortcuts
08-03-2009, 10:18 PM
well that makes sence why it did not work! i got my money back for ark500 i thought they where trying to make me pay for the ark500 you know nothing free!!!!! but the win500 was free and worked real good . so again thank you . you saved me 40 dollars more to pay bills. also i added you as friend ! i hope you did not mind,hope you do same
08-04-2009, 09:51 AM
Just on a side note, people generally end sentences with a period, not multiple exclamation points. Also, there are several threads on the problem with Butel software and the new Radio Reference web interface. Just a suggestion that maybe you might want to look at the forum before starting yet another one.
08-04-2009, 05:58 PM
Did not ask you
I looked did not see any thing about butel ,And im not applying for job i just asked for help .And got it
08-04-2009, 06:04 PM
But thanks for english lesson!
08-04-2009, 06:12 PM
But i will try do better.
