Originally Posted by mobile1
So I put in my TSYS objects and now I want to put in my TGRP objects so I select new item at end from the edit menu and I keep getting another TSYS object that I don't want. What am I doing wrong ? This worked ok for me before, but not now. Don........ some help........please.
Originally Posted by TES
Try clicking in the TGRP area of the window BEFORE selecting the new item at end from the edit menu.
You will find a
WIN500 step-by-step illustrated help file here. Click on "Adding Individual TGs."
1. After selecting the TSYS Objects tab, select the system above the window where you want to add the TG(s).
2. Click on "ID" below the window.
3. Use Ctrl + Shift + N on computer keyboard or click on Edit > New Item at End. The TG added will be a Wild Card TG and can be scanned as a Wild Card or you can edit it to make a specific TG by changing the information in the fields on that line (ID numbers will be assigned by the program automatically).
4. Repeat as necessary to add as many individual/specific TGs as you want.
