Old 08-02-2009, 07:36 PM
Default arc246t software and rr import how to load into scanner
Ok so I have the latest version of arc246t select internet import from rr the software connects and shows the system and talkgroups I have selected how do I get this data into the scanner?
Thanks for any help
Tim
Old 08-03-2009, 03:42 PM
captclint's Avatar
Thanks for any help
Tim
Connect your scanner(if you do not have RS232, then you will need a USB adaptor) Go to BC246T Menu, Select RS232 setup, and try auto detect. If it detects, Set the baud rate to 57600, and click OK. Then Click on BC246T, Send data menu, select all, and off you go. If you do this again, be sure that you check "overwrite systems with the same name"
Regards,
Clint Chamberlin
Luzerne County, PA
Old 08-03-2009, 06:59 PM
Hi Clint !
Thanks for responding....
Actually the problem I am having is importing the data from the rr internet screen in arc246t since I upgraded the program.The update connects and downloads the data from rr no problem but the create system button is missing on the rr screen ,,,,,is anyone else having this problem?
Tim
Old 08-03-2009, 07:12 PM
fmon's Avatar
Hi Clint !
Tim
ARC has not upgraded to the new RR Lib.dll for any software. This needed info has been advertised for several weeks and required as of Aug 1.
Frank
RR Wiki Programming Shortcuts
Similar Threads
Are you looking for software for your scanner? ka3jjz Scanner Programming Software 3 10-25-2009 06:00 PM
any programming software that supports the RR - CD import? torontokris Scanner Programming Software 3 01-06-2009 04:13 PM
*!@#%*!!! ACR300 software/PSR300 scanner 2alpha56 Utah Radio Discussion Forum 14 10-26-2008 03:38 PM
Bearcat Scanner Software rbrochon Scanner Programming Software 5 04-07-2007 08:45 AM
New To Scanner Software spitnsand Scanner Programming Software 3 03-16-2007 03:58 PM
