Old 08-05-2009, 04:29 AM
peterjmag's Avatar
Send a message via AIM to peterjmag
Question Win 97 Problems?
I reinstalled my OS today and previously had had Win97 version 1.21 It worked just fine with no issues. Now today I tried to install the new 1.24 version and I keep getting DLL errors. I have followed all the instuctions on the web page and still can not get Win 97 to load. What am I doing wrong? Why all the headaches? Thanks...
P.J.
P.J. Maguire KE5JVM
W5YJ OSU Amateur Radio Club http://w5yj.okstate.edu/
GRE PSR-400, Yaesu FT-250R, Icom IC-F11, Icom IC-F21
Old 08-05-2009, 04:11 PM
Bucko's Avatar
Do you have Microsoft's .NET installed ( at least version 1.1) ? Win 97 version 1.22 and up require it.
Old 08-05-2009, 04:23 PM
OH/WV DB Admin
Send a message via MSN to mtindor
There is a previous thread that already discusses this (do a search - it's a long one now).
Problem with WIN500 Ver 1.84 Just Released
As already mentioned, make sure you have .NET 1.1 installed.
Also, you may need the updated MSCVR71.DLL - I don't know if this would be needed for Win97 or not. It is needed for Win500 for some people. I believe both of these things are discussed in the above thread as well as on the Starrsoft site.
If you have troubles, install the latest version in a brand new (empty) directory. Run the Win97.exe from that directory and see if it works. If it still complains about a DLL error, copy the MSCVR71.DLL file that you downloaded into that new Win97 directory. Register the DLL using a syntax such as: regsvr32 c:\newWin97Directory\mscvr71.dll . Then try to run the Win97.exe from that directory.
If you still have problems, paste the exact error message that you get - that will surely help Don out.
And please, make sure that you do have .NET 1.1 installed - If you got any errors installing .NET 1.1, then forgot about proceeding any further until you resolve that. And you may want to reboot after installing .NET 1.1.
Similar Threads
Win 97 is super! bgkoe Scanner Programming Software 5 03-31-2009 11:18 PM
PSREdit300 and Win 97 not working ki4rvh Scanner Programming Software 6 03-07-2009 10:32 PM
Parallels and Win 97 bgkoe Scanner Programming Software 2 02-26-2009 12:36 PM
Pro 97 reception problems lunercrab Radio Shack Scanners 10 10-12-2008 03:29 AM
win 97 files rjz7443 Radio Shack Scanners 2 09-12-2007 09:22 AM
