Old 08-06-2009, 01:57 PM
torontokris's Avatar
Send a message via Yahoo to torontokris
Default ARC396PRO 3.1 import window gets cut off at bottom
Not a major issue just a MINOR one but my ARC396PRO import / webservice window (when you go to import from radio reference webservice) is too "long" and the bottom gets cut off by the taskbar
I cant hit "import" or enter custom system names.. without moving the taskbar to the side of the monitor.
Im using 1024x768 (largest I can do with this older monitor).
No huge deal, I can move my taskbar to the side.. just wanted to report it / FYI
Old 08-06-2009, 05:59 PM
I have the same problem while trying to use my netbook which is 1024x600. Unfortunatly moving the task bar is still not enough room for me. I hope they work out a fix for this problem soon.
Similar Threads
ARC396Pro and 996 vs wrong conventional alpha-tag import slypx Scanner Programming Software 2 01-05-2009 12:46 AM
