Old 09-28-2009, 01:25 PM
Default ARC 500 Question
I would like to add more trunk systems to an existing file that I have loaded onto my Pro 106. After I download the data from the RR database I then assigned the data to a vacant scan list and attempt to load the data to the scanner. When I do this the data will not load into the vacant scanlist. What am I doing wrong? Can't I simply add data to any vacant scan list or do I have to reload the original file to include the new data into the scanner? I know there has to be an easy way to do this, but I have not been able to figure it out. Thank-you in advance for help.
Old 09-28-2009, 01:36 PM
If what you are asking is if you need to reload the entire profile, the answer is yes. Unlike the Uniden scanners, you can't just add a system to the scanner. At least not with ARC550, and it's the only program I could get to connect to the scanner with my Acer Aspire One. Other programs may allow single system upload, but I never got to try.
