Originally Posted by MBECKNELL
Is there any thing i need to do to get the radios ids to show up on talk groups in the Win 96 software???
sorry guys must have had a brain fart i meant the win 500 i dont know what i meant when i said win 96
Okay, assuming you really did mean WIN500, you will find "Show Radio IDs for group calls" on the right side of the page under the Extended Settings tab. Placing a check mark in that box and uploading to the scanner so it sees the change will do the trick. Gathering RIDs will only work with a Wild Card TG. However, if you have a Radio ID you want to track, it can be programmed in using DEC format like any other TG object and be scanned as such.
