Old 10-02-2009, 09:00 AM
Unhappy win 500 question
if i modify a template is there a way to reload it back the the pro 106. i just keep getting the same talk groups in the same order when i reload the new template ???? i have vo1.80 is there a update to this one yet
thanks matt
Old 10-02-2009, 09:27 AM
jamesa53's Avatar
Maybe this is too elementary, but you have to save the modified template as a file (just to be safe) then select "Upload to Scanner"......it should upload your changes to the scanner.
iScan (PRO-107) (RS Factory Software)---PRO-106 (Win500)---PRO-162 (Keypad)----PRO-96 (Win96) PRO-92 (Plain and B model) (Win92)-----PRO-90 (Keypad)---BC-100XLT (Keypad)---PRO-4 (Xtals)
Old 10-02-2009, 09:40 AM
Highpockets's Avatar
thanks matt
It's up to v1.89
Win500: PSR-500, PSR-600, PRO-106, PRO-197 Scanner Software for Data Management, Monitoring, and Control
Steve
BC780xlt ~ BC785D ~ BCD996XT ~ PSR600
Old 10-02-2009, 10:22 AM
ok the weird thing is i have saved it.
Old 10-02-2009, 10:40 AM
I just saved it a reloaded it to the scanner an still the same stuff i have no clue what iam doing wrong. should i wipe the scanner out and reload ever thing again.
Old 10-02-2009, 11:10 AM
qlajlu's Avatar
thanks matt
As Highpockets indicates, there has been a couple of updates to the software and you need to update your software to the latest version of v1.89.
Would you also describe what changes you are trying to make and what you have done to make them.
If you can read this, thank a teacher - If you are reading it in English, thank a veteran.
Drive no faster than your guardian angel can fly.
Time has a way to corrupt everything.
Old 10-02-2009, 11:20 AM
here is what i have done on a trunked system i have moved some talk groups around in order just like on the real radio that we have so i can be set up just like the radio the software will not seam to save those changes
Old 10-02-2009, 12:23 PM
You changed the order of talkgroups within the software... did you also "renumber" them (the "ID" column)? If not, your changes won't have any effect on the scanner - the scanner always displays objects sorted by Object ID.
To renumber the Object IDs of your rearranged talkgroups within Win500, select those talkgroups on the TSYS Objects tab, right click on one of the selected talkgroups, and select "Reassign Object IDs..." from the menu that appears. You'll be prompted for a starting ID # as well as a step value.
Old 10-02-2009, 09:32 PM
hey don thanks for the info i should have know that any way ha ha thanks again brother
