Old 10-12-2009, 09:54 AM
Question no squelch on pro 197
iI DID THE WIN 500 DOWNLOAD AND PUT IN MY FREQUENCIES TO THE SCANNER SOME I PUT IN SCANLIST 1 SOME SCANLIST 2 BUT NOW I HAVE NO SQUELCH AND WHEN I PUSH SCAN IT ONLY SHOWS IT SCANNING LIST 1 ANY SUGGESTIONS THANKS
Old 10-12-2009, 11:58 AM
qlajlu's Avatar
I'm not sure about the squelch. I don't hear a squelch tail when scanning a trunked system. As far as scanning Scan List 2, simply press the number 2 key on the scanner's key pad while it is scanning and that will enable Scan List 2.
Also, please do not type in all CAPITAL letters. It is like yelling in person.
If you can read this, thank a teacher - If you are reading it in English, thank a veteran.
Drive no faster than your guardian angel can fly.
Time has a way to corrupt everything.
Old 10-12-2009, 12:29 PM
MPSCS's Avatar
If you're monitoring a digital system, the squelch is disabled because it's not needed.
Old 10-12-2009, 07:20 PM
Question Pro 197
Sorry for all the capital typing not very good at this .after i enable scan list 2. should it scan through 1 and 2 scanlist at the same time . also when i download and click import and upload to scanner .is this all that i need to do . i wont have to do any changing on my own on anything will i .does upload put everything in the trunking and talk groups like they should be to monitor a system that you pick.
Old 10-12-2009, 09:16 PM
qlajlu's Avatar
Well, it isn't quite that simple. What programming software are you using? Have you ever used a scanner before?
Old 10-13-2009, 09:36 AM
Question Pro197
I HAVE programmed the older ones where you punch in the frequencieslike on my bearcat 340 but i havent programmed one like this one before i downloaded the new win psre500 1.87 releases and uploaded to the scanner from it. i just clicked my state wva county randolph and then clicked wva interoperability in the 3rd drop down window then selected transmitters i selected elkins /southharman /north harman . then i selected talk groups troop 3 elkins then i clicked import then went to top of page and clicked upload to scanner it all went in wether or not i have done it right i dont know any suggestions please bare with me on my posts like i said before im just trying to learn how to do this your suggestion of using the usb cable really helped alot and i do appreciate it any help would be appreciated
Old 10-13-2009, 10:34 AM
qlajlu's Avatar
PUNKY, it sounds to me like you have done everything correctly, but something is missing. I do not use, nor am I familiar with PSREdit so at this point I am hoping someone else will lend a hand here. If you were using WIN500 I would ask you to send a copy of the file you uploaded to me so I could try to locate the problem.
Hang in there. In the meantime, open your PSREdit and look at the file. Make sure all of the TGs are assigned a Scan List.
Are you hearing anything at all when you go into scan?
Old 10-13-2009, 11:41 AM
fmon's Avatar
I imported just as you did and used default Scanlist 1. Yours will work but you've limited the WVInop to troop 3 which may be somewhat new with little activity for Randolph CO.
I would have selected Controls and Alts, which would give you two more frequencies in case they change to an alt frequency. Also, a wildcard and private wildcard may be prudent for your new area. These could be placed in Scanlist 2 so you could choose when to monitor them. Ie, if you check Enable Hit Counts in General Configuration and are away from scanner for period of time, using list 2 will identify talkgroups not yet listed for your area. Of course, the scanner should be running and you can also keep list 1 enabled.
On return, simply download from radio to check hit counts.
I scan WVInop at least once a year while traveling through (both directions) on I-64.
Frank
RR Wiki Programming Shortcuts
