Old 10-16-2009, 11:39 PM
Default pro97 and arc300
Hello was wondering if someone could answer a couple of questions for me? Im trying the butel arc300 free 30 day software for my pro97. Can you put more then 1 trunked system into a bank using this software? Second question is when i import the trunk system from the radiorefernce website it puts all the trunked system freqs. at the beginning of the bank its overwriting the freqs i have already have placed there.
Old 10-17-2009, 01:50 AM
gmclam's Avatar
Default PRO-97 programming
This is more of a function of the radio than the software. If the systems both Motorola, then it is possible but not recommended. There are some tricks required to make it work and it is likely you'll have a collision of TG IDs. If the systems are EDACS or LTR it is not even possible.
You need to read data from the radio and save that file. Then import and merge the data. When you write to the radio it ALWAYS overwrites everything.
PRO-95 | (customized) PRO-10 | PRO-97 | PRO-77 (customized) | PRO-92 | PSR-300
