| Scanner Programming Software This is the place to discuss scanner programming and control software. |
10-21-2009, 12:49 PM
Where are the protocols documented?
I like to tinker with software and I was looking for the comm protocols in general and those of the PRO-160 and PRO-96 specifically. I can't seem to find them documented anywhere. Is there some reason for that? I already looked at some of the raw data using some free software to "tap" the comm port while ARC-160 talked to the scanner. I suppose I could reverse engineer most of it, but I'd rather not. Anyone know of any documentation out there for the comm protocols?
10-21-2009, 01:00 PM
The PRO-96 protocol is a proprietary document requiring a Non-Disclosure agreement with Radio Shack/GRE.
I don't know about the PRO-160 protocol.
10-21-2009, 01:42 PM
Uniden Product Manager
Also, the PRO-96 doesn't have much in the way of protocol. All it will do is transfer complete memory images. So, your application must build a complete image of the PRO-96's memory and transfer it en masse.
Uniden publishes the protocol for all scanners for anyone to use.
10-21-2009, 03:15 PM
Can you point me in that direction? I've been on the Uniden site and have not seen such info. As a matter of fact, I have sent a couple of emails to Uniden (over a month ago) and received no replies. Thanks!
PRO-95 | (customized) PRO-10 | PRO-97 | PRO-77 (customized) | PRO-92 | PSR-300
10-22-2009, 11:12 PM
For the Pro96, I have some code in VB6 here:
Radio Shack Pro-96 Developement
There are two files that describe the Comm Protocol and the Memory Map...
10-23-2009, 09:59 AM
Cool, thanks for the help. I'd like to capture the control channel information while still scanning. I record the local pd and I'd like to be able to associate the talkgroup with the recorded audio. Just watchin' the watchers.
10-23-2009, 11:54 AM
Can you point me to the BC780XLT protocol? That doesn't seem to be on the site. Thanks in advance.
KA3FYU
10-23-2009, 11:59 AM
Can't do that with the Pro96.
10-26-2009, 08:50 AM
UPMan, any update?
KA3FYU
10-26-2009, 09:27 AM
That one predates me by several years, so I don't have it. However, a quick Google led me to Remote Scanner Control Protocol
10-26-2009, 10:15 AM
Thank you; I had known about that one but never knew if an official Uniden document was available.
Much appreciated!
KA3FYU
