I have a Pro-197 scanner set to scan a local P25 800 Mhz trunking system programmed with latest version of WIN500. I have great signal, but the audio is garbled. The talkgroups in questions are clear and not encrypted. I have swapped antennas, used coax, used direct connection with different antenna, and more.
Should I consider changing the settings for the P25 settings in an effort to help? If so, what do I change?
Thanks!
Thanks!
