Old 04-28-2010, 2:47 PM
Default BCT15X Programming Software?
I'm a GRE user, so am schooled in Don Starr's excellent software, but a friend of mine just got a BCT15X. It will eventually wind up providing a feed here, replacing an ancient BC590XLT.
What is the best software to use to set the radio up? I am not sure if the software is just used for programming or operating as well.....He will be using the Radio Ref streaming software for providing stream audio AND he wants to stream the alpha tags as well.
Any suggestions for software compatible with the above needs?
Thanks in advance!
Old 04-28-2010, 2:56 PM
KE5BCP's Avatar
Thanks in advance!
Always look to the Wiki:
BCT15X - The RadioReference Wiki
Old 04-28-2010, 10:47 PM
Thank you. I did. Why, I even checked Google.
I saw 7 alternatives in the Wiki. My original question was 'what was THE BEST'.
Does anyone else have any input? I'm not sure if anyone is streaming a BCT15X yet. Looks like front-panel programming is fairly time-consuming (at least it is on the GREs).
Old 04-29-2010, 12:55 AM
eaf1956's Avatar
Post Software
BEST is iffy..... Tell him to try FREESCAN after all it's "FREE"
Old 04-30-2010, 4:34 AM
FreeScan works well for a basic program and is Free. I also use ProScan and it's the best of the pay programs by far.
Old 04-30-2010, 6:23 AM
WisconsinRailfan's Avatar
I use freescan and really like it, and like others mentioned its free. I believe Proscan offers a free 30 day trial, I tried both, and freescan does everything I need for my BCT-15x.
Ham Radio: Icom-718 - Yaesu VX-170 - Yaesu FT-1500M
Shortwave: Kaito KA1103
Scanners: Pro-97 (Tapped) - Uniden BCT15x(2)
Old 04-30-2010, 11:39 AM
Thanks guys! I remember back in the day I think the BuTel was the only game in town, so this is news to us. I'll pass it along, and hopefully the scanner will be on line here shortly!
Old 04-30-2010, 12:03 PM
eaf1956's Avatar
Post Butel
I have FREESCAN, PROSCAN, ARC996, and ARC XT. I use them all, the one thing I like about ARC in the CLICK and DRAG QUICK KEY selection. Makes it so much easier to know which KEY is assigned to what on SYSTEMS and GROUPS. The thing I don't like about ARC is everytime you upload to the scanner everything becomes ACTIVE where as FREESCAN only leaves active what you had selected. For example, if I had SYS 1,3,5 active loaded the scanner memory to FREESCAN and edited things and reloaded it to the scanner the same systems would be active as before. ARC would make ALL systems active, makes me go in and shut off the ones I had OFF before.
KC9LVX Evansville, In and Henderson, KY feeds
Old 04-30-2010, 12:46 PM
Butelsoftware's Avatar
Send a message via Skype™ to Butelsoftware
That's a setting in the software, in the upload window select 'Send System Quickkey Status' and then software will enable only the system you selected.
Gommert
Butel Software
http://www.butelsoftware.com
Dutch Design
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
