- Joined
- Apr 17, 2011
- Messages
- 233
I've had this peculiar problem with FreeSCAN for several months, and was hoping it would just cure itself with the next release. No such luck.
The symptom is this failure immediately on startup, before loading any of my BCD396XL files.
Image below showing:
I can "Continue"; the program starts and appears to work fine, so it's more just a bother than a failure.
Is there any startup file or configuration info that FreeSCAN loads at startup? Anything I can flush or clear?
The program used to work fine, so it must be something about my system or configuration that has flustered the startup. Ideas?
Thanks!
Code:
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at FreeSCAN.frmRecord.SetupRec()
at FreeSCAN.lblSiteNote.frmSystemEditor_Load(Object eventSender, EventArgs eventArgs)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Thanks!
