| Scanner Programming Software This is the place to discuss scanner programming and control software. |
01-31-2012, 12:51 PM
Every morning I come down to my computer, during the night ID tracker stops on its own with an error, I understand it doesn't like something in the program but I can not find what the error is talking about. Any Ideas thanks.
060:10:07.120 Application Error! - Step: Reset ID
Error: Arithmetic operation resulted in an overflow.
Source: IDTrackerIII
Stack Trace:
at IDTrackerIII.modUnidenIV.TrunkTrackerIV()
Module: modUnidenIV Routine: TrunkTrackerIV
060:10:07.129 Error Details
Error: System: 69 - KC MARRS P25
Site: 0 - KCMO MARRS
Frequency: 2870392500 ID: 0
Info:
02-01-2012, 04:43 PM
Stack Trace:
Info:
I will look into this. At first glance it looks like something to do with the frequency: 2,870,392,500 which is 2.8 GHz.
02-08-2012, 10:50 AM
ID tracker III not saving setting,1.11.1 ?
Hi all like I've said,ID tracker III is the best.But in this version and the couple before this one.The id alignment dosent save to center? Mike
RADIO SHACK PRO-96/RADIO SHACK PRO-2036/RADIO SHACK PRO-197/GRE PSR500/UNIDEN 200XLT/YAESU VX-7R/KENWOOD TM-V7/UNIDEN HP-1(E). callsign KB3LZZ
02-08-2012, 11:21 AM
Seems to be working well on my little old Dell Laptop with no error's. If i have any problems i will report in.
02-08-2012, 04:46 PM
In what list? Could you post an image?
02-09-2012, 07:17 AM
H David as you can see in snipit all lines? thanks Mike http://forums.radioreference.com/att...1&d=1328793170
02-09-2012, 07:22 AM
Its really no big deal just have to set to center on every restart of id III. thanks Mike
02-09-2012, 05:04 PM
Right, but it should save it. I am seeing the same problem here so I should be able to fix it. I never really noticed since I like mine right justified.
02-09-2012, 06:39 PM
Column issue is fixed. Unless something comes up, should be released on Friday.
02-10-2012, 06:36 AM
Thank you David as always you the man. Mike
02-10-2012, 01:32 PM
Thanks David the new version did it,Saving to center. Mike
