Old 02-02-2012, 07:19 PM
Default Win500 pro106 Question
I use this software to program my scanner. I mostly use the radio on rechargeable batteries. Is there a way with the software to have the lcd dispaly light to come on when it stops on an active channel? How would you do that
Old 02-02-2012, 08:06 PM
N0WEF's Avatar
Location: Mpls, MN. (But work in NY,CA,MI,AZ,KY,TN, And IN.)
If I remember correctly:
Simply highlight all your conventional objects by going to the CONV objects tab, click the first conventional object, then scroll down to the last one, hold shift and click on the last conventional object, and then choose "On" on the right side of the window underneath "Backlight", and then do the same for your trunking talkgroups. Then save and upload it to your scanner.
Old 02-02-2012, 08:27 PM
DDan's Avatar
I don't think that is possible. Here is the link to possible Light modes and that isn't listed as an option.
Easier to Read Pro-106/197/PSR500/600 Digital Scanner Manual
73 de W6KRU - Dan
BCD396XT BCD396T PSR-500 FRG-100 PRO-43 PRO-90 PRO-2050 FT-857 FT-90 VX-170 VX-3
RS 20-176 | Maxrad MFB8133 MYA8256 MUF8043 MLB3400
Old 02-02-2012, 08:31 PM
N0WEF's Avatar
Wouldn't this work manually?
1.)Press PGM
2.)Press the F2/Edit key
3.)Press the F3/Find key
4.)Press the F2/Text key
5.) Press the #1key and that will show the numbers above. Type in the talk group# in there. .
6.)Press the F1/Ok key
7.)Press the F2/Edit key
8.)Press the down arrow key to backlight. Press the right arrow key to On
9.)Press the down arrow key to the Alarm: Press the right arrow key to whatever alarm you want
10)Press the the F1/Save key
Now the backlight should only come on when theres a transmission and alarm sound if you chose one.
if the other option didn't work
Old 02-02-2012, 08:43 PM
DDan's Avatar
1.)Press PGM
You are right. It can be set on a per channel basis. I was looking for way to set it globally.
73 de W6KRU - Dan
Old 02-02-2012, 08:45 PM
N0WEF's Avatar
You can't do it globally, but you can in chunks with my first post.
Old 02-02-2012, 09:23 PM
InlandAZ's Avatar
Have you tried setting Backlight to "On" in the Alert section? It can be done for both Conventional and TSYS objects.
Maybe I just don't understand the question?
Old 02-05-2012, 12:49 PM
Default Backlight
Inland it appears that your suggestion worked. Thank you
