Old 08-31-2012, 3:25 PM
Angry Programming Pro-197 with ARC500 Software
I am tring to import freq. from RR using ARC500 Software. The Local police frequencies use p25 trunking system. When I import they show up as conventional channels. When I program the scanner with what
I import ..I hear nothing. Please Help...Thank You
Monroe County New York
Rich
Old 08-31-2012, 5:30 PM
Butelsoftware's Avatar
Send a message via Skype™ to Butelsoftware
What is the link to this trunk system? The RR database only lists conventional P25 for Monroe county law enforcement.
Gommert
Butel Software
http://www.butelsoftware.com
Dutch Design
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 08-31-2012, 5:36 PM
Chauffeur6's Avatar
DB Admin
Correct, those are conventional P25 frequencies in Monroe County, not a trunked system. If they were part of a trunked system, they would not be listed in the conventional section of the page like they are.
Old 08-31-2012, 6:22 PM
I notice in his post he does not have the premium membership to RR... Yes I know that ARC500 is good for 2 free downloads but it only good for 14 days I believe.
Old 08-31-2012, 7:20 PM
Sorry for the misunderstanding on the p25 conventional frequencies . I have used other software in the past and didnt have any problem with programming this scanner. I can program the scanner with no problem using ARC500 software... but I hear no audio on the p25 frequencies.
Old 08-31-2012, 7:35 PM
Chauffeur6's Avatar
DB Admin
Make sure you have the latest version of ARC500 installed. There was an issue with these P25 conventional frequencies a few months ago, where the NAC was not getting imported correctly. I don't remember the specifics and whether a software update was required.
Also, take a look at the NAC's after they are imported and make sure they match what is in the database here. If they aren't correct, you're not going to hear anything.
Old 08-31-2012, 7:52 PM
I was just going to post that I found that the NAC's did not import correctly. I changed them and all is working fine....Thank you
