| Scanner Programming Software This is the place to discuss scanner programming and control software. |
11-16-2012, 8:18 PM
ARC XT Question
Testing some web importing using this software, I think I found a bug. Frequencies that use a DPL tone, the tone is not importing into the software. PL tones seem to work fine but DPL's are not. If this has been asked before I apologize. Software bug or database bug?
11-16-2012, 10:27 PM
Wiki Admin Emeritus
In order to test whether this is a DB issue, we need to know precisely what you were importing- we can then try it with FreeScan and other software...Mike
11-17-2012, 6:01 PM
I tried it with a few Counties in MA. First Barnstable then Plymouth then Norfolk, and the results are conclusive. Any town that uses a DPL, that tone (DPL) is not importing into the ARC software. PL tones are importing fine.
11-17-2012, 6:31 PM
Confirmed! And I tried a few in PA with same results as in MA. I have XTpro V1.8 build 3.. This must be a recent bug, as I never had that problem with earlier versions.. Hopefully, Gommert from Butel will see this and comment. BTW, FreeSCAN is OK, so it is not a DB issue.
Another recurring bug is the failure to auto load the saved profile. It just started doing this, and not when I upgraded. No, I don't have the virtual control checked. I seemed to recall Gommert recommending deleting the folder "c:/butelsoap" Did that without any improvement. So I just restored it, and now the auto load is working, but it was acting up before I deleted it???.
Regards,
Clint Chamberlin
Luzerne County, PA
11-17-2012, 6:51 PM
Confirmed here as well.
DPL's are not importing using ARC-XT PRO - V1.8 Build 3.
Also confirming that those same DPL's do import properly when using Free Scan.
11-21-2012, 8:38 AM
Build 4 released today fixes the DPL issue. Also seems to have fixed the profile auto load, although I have seen this to come and go. Hopefully, it will continue to work.
Regards,
Clint Chamberlin
Luzerne County, PA
11-21-2012, 8:20 PM
Is this ARC PRO?
11-22-2012, 9:21 AM
The build resolved the issue for me also (see below):
11-22-2012, 9:30 AM
Using ARC Basic here, the update may not have been applied to this?
11-22-2012, 9:38 AM
It would be very unlikely they would do one and not the other. Their software update versions page is way out of date, so I can't tell. Just Downloads and see if it is updated
Regards,
Clint Chamberlin
Luzerne County, PA
11-22-2012, 10:03 AM
Will try later and report back.
11-23-2012, 8:44 PM
My version of ARC XT Basic version 1.8 Build 1 shows as the most up to date version. Hmmmmm......
11-24-2012, 7:56 AM
Since there are more things that can go wrong with the Pro vs Basic, it does not surprise me that build #'s are different. Did latest version solve the problem??
Regards,
Clint Chamberlin
Luzerne County, PA
11-24-2012, 9:16 AM
Apparently the update to the PRO version has fixed the issue, but not on the BASIC version.
11-28-2012, 8:04 PM
Still no change. Hoping Gommert from Butel sees this thread and has some input?
11-29-2012, 7:56 AM
Update for basic will be available in 2 weeks.
Gommert
Butel Software
