Old 11-17-2012, 9:45 AM
RonnieUSA's Avatar
Question ID Tracker 3
Is there any way to change the date format?
Instead of 12/11/17 to 11/17/12
Radio Shack Pro-197 - Uniden BCT15X
Win500 - ARC500 - FreeScan - ARC-XT-PRO - ID Tracker III
Old 11-17-2012, 9:56 AM
Sure Ronnie,
Go into settings -> display -> List Time Format then change it to mm/dd/yy hh:mm:ss
Richard
Old 11-17-2012, 10:01 AM
RonnieUSA's Avatar
Originally Posted by Richard View Post
Sure Ronnie,
Richard
Thank You very much.
It's working right now.
Old 11-18-2012, 9:38 AM
Ronnie, FYI - I made that format the default so that the date will sort correctly. Other formats will not sort properly. However, I may look into the possibility of making the grid sort all formats correctly.
David M. Hitchner - K5DMH
Baton Rouge, LA
Baton Rouge Area Scanning: http://bellsouthpwp.net/k/d/kd5eis
ID Tracker/ID Tracker II: http://bellsouthpwp.net/k/d/kd5eis/i.../IDTracker.htm
Old 11-18-2012, 10:28 AM
RonnieUSA's Avatar
That would be great.
Thank You for a great program.
To bad We can't use it to upload to the scanner. (Hint)
Old 11-19-2012, 5:34 PM
I am not going there. :-) Too many differences in the scanners. Even I use other software to program my scanner although there have been a few time when I thought of writing something myself due to limitations of some of the apps.
Baton Rouge, LA
