| Scanner Programming Software This is the place to discuss scanner programming and control software. |
12-02-2012, 4:30 PM
Grrrrrrrrreat!
Looking forwards to checking it out!
 Supporter of Broadcastify!
Play "Travel Scrabble" here: Travel Scrabble (Word Game)
For ALL (not some) have sinned, and fall short of the glory of God! Romans 3:23
Don't be fooled, I'm not a LEO!
12-02-2012, 4:43 PM
It doesn't look like it wants to install on Windows 8. I even tried compatibility mode.
GRE PSR-600, BCD996XT
Win500, Freescan, ID Tracker III
12-02-2012, 5:00 PM
It works great on Windows 8 Pro.
Radio Shack Pro-197 - Uniden BCT15X
Win500 - ARC500 - FreeScan - ARC-XT-PRO - ID Tracker III
12-02-2012, 5:07 PM
I have 8 Pro with Media Center. It crashes here on mine when I try to install with a couple of errors.
12-02-2012, 5:13 PM
I had no crashes, or any problem installing it.
Make sure You have net framework installed, 3.5 I think.
12-02-2012, 5:17 PM
I have netframe 3.5 installed. Quicken requires it.
12-02-2012, 5:25 PM
The two errors are 2503 & 2502
12-02-2012, 5:40 PM
I just tried the executable and it works fine.
12-02-2012, 5:42 PM
Great to hear.
12-02-2012, 8:16 PM
Can anybody help me getting started with ID Tracker? I got it work on a control channel but no id's or nothing has been decoded.
12-03-2012, 9:22 AM
vinsky:
If your scanner is a GRE/RS you will need to make sure a scanner image is loaded.
Second, unlike Unitrunker or Trunk88, your scanner doesn't sit on a CC.
IT HAS TO BE SCANNING.
See the help file for more info on how to load the memory of your scanner into the software!
12-03-2012, 11:48 AM
I use the program with a 996XT. So I program the Edacs system in the scanner and I put it in ID Search or ID Scan?
12-03-2012, 4:49 PM
If you are searching for new IDs, then put the scanner in ID Search mode. If you only want to follow ID already programmed into the scanner, use ID Scan.
