Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #41 (permalink)
Old 02-03-2013, 6:53 PM
RonnieUSA's Avatar
Originally Posted by alwayslookin View Post
As of now yes but I think it is wrong I typed in the external Ip address and port number into win 500 and its connected Im not at home right now so I can't unplug the router and test it. As of now the Ip hasn't changed yet according to no-ip. Am I spose to enter my external IP into win 500 or my no-ip address I created? Cause when I did it would not connect that way just external add only will connect. Thanks.
You don't use the external address, You use the no-ip address to access your scanner.
PSR-800 - BCT15X - FreeSCAN - NooElect R820T2+ SDR - NooElect R820T2 SDR - DSDPlus Fast Lane
  #42 (permalink)
Old 02-03-2013, 6:58 PM
alwayslookin's Avatar
Ok well there is something still wrong my no-ip address is ryanpedro.no-ip.org I type that in and port 8086 into win 500 and will not connect. only way to connect is my external ip of 74.132. 167. and the port number then works fine until router changes ip.
  #43 (permalink)
Old 02-03-2013, 7:04 PM
RonnieUSA's Avatar
Ok lets start over, in the router port forwarding page the IP Address should be 192.168.1.102,
now in the NO-IP app change it back to whats posted in this pic You posted, but put the check mark in the bottom box, enable system service, then restart it all, and then see if it works.
  #44 (permalink)
Old 02-03-2013, 7:23 PM
Ok did that restarted cpu tried to connect win 500 with no-ip and port number still unable to connect. But will connect still with external ip and port.
  #45 (permalink)
Old 02-03-2013, 7:39 PM
RonnieUSA's Avatar
There is something that is being missed here, You shouldn't have to use your external IP Address.
See if this link helps you any>> http://support.no-ip.com/customer/po...rwarding-guide
  #46 (permalink)
Old 02-03-2013, 10:38 PM
Default Win500 Control/Monitor
It is the same address as I have setup I believe. Here is the screen shot of ip config.
  #47 (permalink)
Old 02-07-2013, 5:48 PM
After days and hours I finally got this all setup the proper way just wanted to thank everyone for all the help. Thanks.
  #48 (permalink)
Old 03-22-2013, 10:52 PM
never mind i figured it out. but i cant be on the same modem to access it right from a phone?
thanks,
matt
  #49 (permalink)
Old 03-22-2013, 11:39 PM
Are you talking about a mobile phone?
  #50 (permalink)
Old 03-23-2013, 9:29 AM
Yes I am on a seperate wifi and I still am un able to connect on a phone?
Thanks,
Matt
  #51 (permalink)
Old 03-23-2013, 10:03 AM
Thanks,
Matt
Are you saying that you have Win500 server running on your home computer and you are trying to access it from your cell phone?
What phone are you using? At this time, the only Win500 client software available is for cell phones using Windows Mobile 5.0 or later for the OS.
Win500: PSR-500, PSR-600, PRO-106, PRO-197, PSR-310, PSR-410 Scanner Software for Data Management, Monitoring, and Control
  #52 (permalink)
Old 03-23-2013, 10:32 AM
I ran mine on the desktop and and used my laptop and mobile phone to connect while I was on the road worked like a charm. But if you are trying to use it from just the mobile alone like fxdscon said you will need a windows mobile phone to run it that way.
  #53 (permalink)
Old 03-23-2013, 11:02 AM
I am using a htc 6800 and have the program insalled but won't connect to the server.
Thanks,
Matt
  #54 (permalink)
Old 03-23-2013, 11:23 AM
Thanks,
Matt
Have you set up port forwarding on your home router for the server, and verified your external IP address?
  #55 (permalink)
Old 03-23-2013, 12:08 PM
no i have not how do i do that?
thanks,
matt
  #56 (permalink)
Old 03-23-2013, 12:15 PM
Log into your router settings and enable port forwarding usally 192.168.1.1 and then port forward 80.
  #57 (permalink)
Old 03-23-2013, 12:17 PM
ok will try.
  #58 (permalink)
Old 03-23-2013, 12:41 PM
still having trouble can you remotely access my computer and help me set it up.
thanks,
matt
  #59 (permalink)
Old 03-23-2013, 12:49 PM
What program do you use?
  #60 (permalink)
Old 03-23-2013, 12:50 PM
teamviewer
thanks,
matt
