Old 02-03-2013, 8:48 AM
kb0rpj's Avatar
Default using Pro96Com to program using win96.
Ok, hopefully this is the right forum but i've running into a bit of a mental block.
I've run pro96com on our local 'MoSWIN' tower and it spits out the frequency tables and i've been able to figure the "ch lo" "ch hi" "offset" and "base freq" the part i run into problems with is the steps/spacing issue.
to properly put in the spacing do i put it in on the win96 steps tab as shown (0.00125) or is it * 1000? (12.5) or something in between.
thanks in advance for any help.
Old 02-03-2013, 9:28 AM
I think I just answered that in your other thread. I think it is your second guess so 0.00125 is going to go in as 12.5. I could be wrong though as this stuff is clear as mud for me not ever needing to mess with custom tables much on my Pro-96. I bought new radios that handle everything so never needed to mess with the custom tables much before. It will be nice to put the old 96 to use again for MOSWIN though if it will work.
