Old 03-15-2013, 6:57 PM
n3xbo's Avatar
Default proscan
I have a bcd996xt and tryed all of programing software and like proscan but have a problem with disconnects 2 Radio reference 4 my feed. I get 4 to 5 disconnects all day when I use proscan. But if I use the software that RadioReference supplies I don't get any disconnects all day. Just wonder if anybody has any ideas why is that might be happening very annoying.
Old 03-16-2013, 8:40 AM
ProScan's Avatar
When you had ProScan streaming to RR, was it on the same computer as ScannerCast?
Was ProScan using the same Server IP Address and port as ScannerCast?
Do you use AVG anti-virus software by any chance?
Can you test with RadioFeed to see if that makes a difference?
ProScan - Taking Computer Aided Scanning To The Next Level!
http://www.proscan.org
bob@proscan.org
Old 03-16-2013, 9:11 AM
n3xbo's Avatar
I am NOT running any antivirus software. When I was running proscan for my feed to RR I did not have scanner cast started. It's on the same computer but not running. I will use radiofeed today and see what it does.
Old 03-18-2013, 9:36 PM
ProScan's Avatar
Curious if you tested with Radiofeed and do you still get disconnects?
bob@proscan.org
Tags
program help, proscan
