Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 05-03-2013, 8:25 PM
Default Uniden BCD996T Software Control and Prog.
I have a BCD996T and have always used the free Uniden software for this scanner. I am curious to know which is the best software for programing and PC control.
Also this scanner has a limit of 250 Talkgroups per trunked system that can be tagged and programmed. I read somewhere before that there is a control software for the 996xt that can allow a lot more than 250 tagged talkgroups per system as long as it is programmed and operated via the software. Naturally if the scanner is running without the pc it would only hold the 250 talkgroups and while connected to the pc via software it would display higher than the limit of 250. If there is a software that can do this please let me know. Thanks.
Old 05-04-2013, 6:56 AM
captclint's Avatar
Mentor
BCD996T - The RadioReference Wiki While there is not much choice, I find ARC to be quite acceptable.
Regards,
Clint Chamberlin
Luzerne County, PA
Old 05-04-2013, 6:23 PM
alwayslookin's Avatar
Proscan works great I love it.
Old 05-04-2013, 6:41 PM
Ronaldski's Avatar
MI DB Admin
UASD from uniden works great and its free, freescan works great and its free!
Old 05-04-2013, 7:03 PM
captclint's Avatar
Mentor
Disregard
Regards,
Clint Chamberlin
Luzerne County, PA
Old 05-04-2013, 7:21 PM
For programming, I prefer FreeSCAN. It's free, it's very well supported, and it works great.
For remote control and recording/logging, ProScan is the way to go. It's not cheap at $50 per license, but that entitles you to install it on two computers (great for remote control over IP), and it's just a fantastic program, also very well supported.
Old 05-04-2013, 8:58 PM
Thanks for the replies. What about the ability to be able to have more than 250 talkgroups (using software only) than what the scanner will hold. Will any of the software mentioned have this option of storing more than 250 tagged talkgroups per system.
Old 05-06-2013, 6:24 AM
Wiki Admin Emeritus
No this is a limitation of the scanner, not the software
