Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 07-10-2013, 8:07 PM
Default GRE 500 LED
Ok question using Win 500 what are the steps to input a red light on my fire channel. Using Wine 500 what do I need to do without screwing something up.
Old 07-11-2013, 12:12 AM
alwayslookin's Avatar
read your file from your scanner or open your file then click on the tab where the freq of the fire dept is wether it be a CONV objects tab or TYSY objects tab and find the freq of the fire dept left click once the to the right where it says LED color change it to red the save your file then upload to scanner. Hope this helps.
Old 07-11-2013, 9:17 AM
Thanks that really helps. So should I have my scanner on or off when I do the upload or should I just have it hook up to the computer when I do the upload.
Old 07-12-2013, 10:57 AM
The scanner has to be connected to pc and turned on in order to do this.
Old 07-13-2013, 3:52 AM
Wirelessly posted (Mozilla/5.0 (X11; Linux i686; U; en-US) Gecko/20081217 Vision-Browser/8.1 301x200 LG VN530)
I would say that unless your scanner is always connected to a computer, if you're just setting the LED on one or two objects, it's probably quicker to do so by hand than by software.
Old 07-17-2013, 9:46 PM
Thanks I got the hang of it now change it today and all is fine. Mind over matter!
