Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 12-17-2013, 7:55 PM
SuperTracker's Avatar
Exclamation WIN500 IS POSSIBLE TO HAVE LCD DISPLAY Group or Radio ID
Seems that this is a normal function for scanners accepting WIN96 programming but cannot seem to make a PRO-106 or Pro-197 display ID via WIN500 ( unless its a "scanner thing" )
Does ANYBODY have any idea if this is POSSIBLE???
Old 12-17-2013, 8:29 PM
Radio ID's can be enabled on the Extended Settings tab.
Look at the far right side of the window, just above the IMPORTANT, click the box (check mark) Show Radio IDs for group calls.
Talk Groups show up by default for Trunking Systems.
Bud
Pro-34/Pro-97/PSR-500/BCD436HP/TRX-1
Old 12-17-2013, 10:17 PM
That is already checked.
All I get on 4th Line is TSYS
Old 12-17-2013, 10:23 PM
Let me re phrase that.
I do get the Radio ID of the unit that is transmitting(which I don't want).
I am NOT getting the GROUP ID.
Wish I could find 'somewhere' where ALL the options on all tabs are explained.
Old 12-17-2013, 10:45 PM
You are getting the talk group ID - it's the text alias you have programmed for that talk group.
If want to see the numerical ID one option is to shorten the text alias you have programmed enough to include the numerical tgID.
Old 12-17-2013, 10:49 PM
I had thought of that but didn't want to sacrifice the text.
So I'm guessing the outcome is that you can't cause it to appear like the other scanners.
We'll I appreciate all that you've provided.
Old 12-17-2013, 11:11 PM
Here's a link to a WIN500 online manual web site. It gives you step by step directions for most settings:
Easier to Read Pro-106/197/PSR500/600 Digital Scanner Manual
Here are the screen shots of my systems General and Extended settings. Hope this helps.
Bud
Old 12-18-2013, 6:32 PM
kg4ojj's Avatar
Using budevans' second screenshot, I would suggest UN-checking the "Show Radio IDs..." box.
Also, try UN-checking the box "Show CC info..."
Of course, these are budevans' screenshots and not yours.
The "Easier to Read" manuals are awesome. I need to buy that guy a cold beverage one day......
Jay Reid ~ KG4OJJ
Old 12-20-2013, 8:11 AM
Banned for duplicate accounts
TSYS and Radio ID alternate on the bottom line when Show Radio ID's for group calls is checked under Extended Settings while the TGID appears on the third line up from the bottom during and/or just after transmission and should look something like this: ID: 12345
