Scanner Programming Software This is the place to discuss third party scanner programming and control software.
Old 01-12-2014, 9:50 PM
frazpo's Avatar
Default Freescan 2.16 is out
Freescan 2.16 is out.
https://sites.google.com/site/sixspotsoftware/downloads
Old 01-13-2014, 12:23 AM
kirk23's Avatar
What is different from the 2.15 version?
Kirk
Pierrefonds (Montreal) Qc. Canada
BCD-396XT......BCD-996XT.....PRO-96......BC-760XLT.....BC-200XLT
Old 01-13-2014, 12:39 AM
Ronaldski's Avatar
Mid-MI DB Admin
FreeSCAN 2.16 Available
Whats New:
-New: Support for BC346XTC (needs testing)
-New: You can now abort a download
-New:CSV Export now exports more fields including NAC and number tags
-Fixed: Google Maps function & Geocoding
-Change: No longer case sensitive when uploading systems and deciding which ones to replace
-New: "REC" indicator will no longer appear in virtual control if recording is disabled
-EZ Grab now recognizes digital & analog TGIDs
-EZ Grab for TGID has an improved algorithm
-Change: Simple View is now set to off by default
-Change: If you have too many errors during an upload, they are now dealt with more gracefully
-Other improvements
I didn't get everything done that I wanted to do with this version but have to release it in the interm at least to support the 346XTC. The System Plotter is down for the count until I rewrite it to use Google's newer APIs, and remote control still isn't available but its getting close Anyways stay tuned for more.
Old 01-15-2014, 11:00 AM
rhaasjr's Avatar
Tested the new version with a display 346XTC. Programmed without a hitch.
Thanks!
Old 01-15-2014, 11:08 AM
Default Wonderful news...
I cant wait to get home later and play with the new version..thanks in advance.
Old 01-15-2014, 12:19 PM
Ronaldski's Avatar
Mid-MI DB Admin
No mention of what the 2.16A version changes are, any ideas?
Old 01-15-2014, 2:52 PM
Default Am I missing something?
Isn't it two replies ahead of yours...??
Old 01-15-2014, 2:57 PM
I would like for FreeScan to be more simplistic with the Easy-Grab feature. Such as an Asterisk as to which columns it might grab from say Excel to import for upload.
just an fyi
Old 01-15-2014, 3:00 PM
cpuerror's Avatar
Turns out there was a glitch with EZ-Grab in the 2.16 version so a quick patch was done.
FreeSCAN for Uniden DMA scanners, IRLP*Me for iOS devices
Twitter - @FreeSCAN
Old 01-15-2014, 3:01 PM
cpuerror's Avatar
just an fyi
Not sure what you mean by this?? It tells you which columns will end up going where right above the grid.
Twitter - @FreeSCAN
cpuerror's Avatar
Thanks!
Glad to hear its working!
Twitter - @FreeSCAN
Old 01-15-2014, 3:04 PM
Ronaldski's Avatar
Mid-MI DB Admin
No... if you read it all, my question was for the 2.16 'A' version not the 2.16 which I already had posted. Cpuerror did answer my question.
Old 01-15-2014, 3:12 PM
Thumbs up
Any chance you'll be reincorporating the blue shading circle to display the radius/coverage of sites? That was really handy to have.
Good work on this latest release; glad to see you're still perfecting an already excellent program.
Chris Harris
Old 01-15-2014, 3:18 PM
Highpockets's Avatar
If I didn't read this thread I wouldn't have known there was an A version, I upgraded to 216 and the Zip file is still named 216, maybe it should be renamed 216A.ZIP for those that already installed 216 and they will notice the A next time they visit the site.
Steve
Old 01-15-2014, 3:22 PM
Ronaldski's Avatar
Mid-MI DB Admin
You should have had a window popup when you ran 2.16 that their is a new version.
Old 01-15-2014, 3:25 PM
Wiki Admin Emeritus
As mentioned in the release notes - Google maps recently redid all their APIs for mapping, so it's going to take some time for him to redo these features. I'm pretty sure this is what you're referring to...Mike
Old 01-15-2014, 3:26 PM
Wiki Admin Emeritus
That's only true if you have the 'check for update on startup' box checked in the Edit / Preferences form
Old 01-15-2014, 3:27 PM
Don't know about anyone else, I got no popup window. I upgraded to A only because of this thread.
Steve
Old 01-15-2014, 3:29 PM
Thanks, I'll look for that feature and enable it.
Steve
Old 01-15-2014, 3:41 PM
Robert721's Avatar
any plans for freescan to work on the BCD 436/536 series scanners? Has always been the best software for the 396/996xt units.
Robert T
K5RLT
BCD536,436, Icom 2820,92 XTS5000
