Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #461 (permalink)
Old 03-24-2014, 12:12 PM
Also using Windows 7 btw
Sent from my HTC One using Tapatalk
  #462 (permalink)
Old 03-24-2014, 12:31 PM
u can use the 9 pin rs232 port on the back not the usb port
  #463 (permalink)
Old 03-24-2014, 12:35 PM
Ok but isn't that backwards from when the bcd396t and xt came or with the serial port 9 pin in the computer not the scanner? How would u reverse that? And what cable? Can I use the one the the GPS uniden cable comes with or a different one?
  #464 (permalink)
Old 03-24-2014, 12:42 PM
Enshrined, this was mentioned in an earlier post:
http://www.amazon.com/dp/B008634VJY/..._26725410_item
Also, if you look back through the posts into last week, you'll find additional comments and answers to your question. Hope this helps.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Rick - KC4S, Amateur Extra
BCD396XT, BCD536HP
  #465 (permalink)
Old 03-24-2014, 12:43 PM
Butelsoftware's Avatar
Originally Posted by calking View Post
Build 16 downloaded and installed, not displaying properly, the main screen in Virtual Control not showing names of frequencies being scanned. When it stops on a frequency it will display the name of the for the frequency and hold it. Then the frequency numbers will start scanning again down in the frequency window. However, the main screen is still holding on the last frequency..
Are you using a 436 or 536?
Gommert
Butel Software
>>> Visit us at the 2018 Dayton Hamvention! SDS100 will be on demo! <<<
Dutch Design: best selling scanner software in the USA
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
  #466 (permalink)
That was supposed to be for enosjones. Blasted auto correct ...
BCD396XT, BCD536HP
  #467 (permalink)
Old 03-24-2014, 12:44 PM
Is this required? I have one that looks similar for the uniden GPS, can I use that or do I need to order that one
  #468 (permalink)
Old 03-24-2014, 12:46 PM
[QUOTE=ofd8001;2160947]I'm seeing the pop-up window only when a Favorites List contains a trunked radio system and then the window only references the TRS. If there are only conventional systems, then the window doesn't happen. Other than having to click OK, it's not a big thing to me.
Something I am noticing is that if I'm in Virtual Control, I cannot do any editing of "stuff".
[QUOTE]
Thanks for the additional information. Mine only has a few conventional systems so I did not notice it. Not a big deal for me cause I know it will get fixed. Just throwing it out there.
  #469 (permalink)
Old 03-24-2014, 12:49 PM
Default Re: ARC 536/436 Beta
Someone else will need to answer that question as I don't know.
BCD396XT, BCD536HP
  #470 (permalink)
Looking at my cable I don't have that one I guess,
  #471 (permalink)
Old 03-24-2014, 12:50 PM
Does the RS232 come with the 536 hp or must it be ordered
  #472 (permalink)
Old 03-24-2014, 1:20 PM
nr2d's Avatar
You need a null modem cable. It is not provided with the scanner. It has been posted elsewhere in this thread as to where you can purchase the correct cable. I got a couple on Amazon for about $6 a piece.
  #473 (permalink)
Old 03-24-2014, 8:25 PM
calking's Avatar
Build 17 is now available. Downloaded, installed and everything running 100 percent no issues....
  #474 (permalink)
If you are going to use the serial port on the back of the BCD536 hp for virtual control, I highly recommend the following cable:
Amazon.com: StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI, Black (ICUSB232FTN ): Computers & Accessories
It has been working flawlessly with ARC536 Pro since Saturday
Currently scanning West Texas with a BCD536/436, TRX-1 and coming soon a Unication G5
  #475 (permalink)
Old 03-24-2014, 8:50 PM
davenlr's Avatar
Originally Posted by lep View Post
Odd, build 16 seems to be displaying correctly on my 436. I know Gommert added the feature at user request to log the trunk freqs but I never understood exactly why that was needed. Never the less, I don't object, I just don't personally CARE which of the known freqs of a trunking system a specific transmission is taking place on, since the very next transmission will likely be on a Different one.
But, as far as I can tell, it all seems to be logging correctly and displaying properly on the virtual display.
Some of us only enter the control channel, then the log would show what all the voice frequencies are. Useful if you have a new site and dont have all the info available.
Scanners: BCD536HP BCD436HP BCT15
Ham: HTX-212 Yaesu 757 Kenwood B2000
  #476 (permalink)
Old 03-25-2014, 5:43 AM
Thanks, there was an issue with 436 display support. Most menu's should work now, for the 436 the virtual keyboard still needs some work.
Gommert
Butel Software
  #477 (permalink)
Old 03-25-2014, 6:21 AM
Donald Roberts's Avatar
Angry
When I use the center on the screen option in the software for info for scanner, it moves the info off to the right
of the radio and Butel software so you see only half. Does anyone use this option
and do they find this,
  #478 (permalink)
Old 03-25-2014, 2:21 PM
I found that to be a problem too and asked Gommert about it. He said that is due to Uniden allowing something like a 64 character wide display for names (even though you don't see all 64 characters).
About the only thing you can do if centering is important and you are willing to invest a lot of time, is to do it manually.
Being the lazy guy I am, I turned the 3 line display off, which makes the channel names larger, then had the program capitalize channel name tags.
  #479 (permalink)
Old 03-25-2014, 4:36 PM
Correct, currently we align the text using the 64 character limit. But that does not give a good result on the scanner's 536 display since it only shows 34 characters and does not scroll
Gommert
www
  #480 (permalink)
Old 03-25-2014, 5:18 PM
lep's Avatar
lep lep is offline
A feature for the log that would be useful would be if columns could be "moved around". That is, I might prefer that the Department column be next to the Channel Tag column. If it was possible for the user to move columns that would enhance the usefulness of the log.
Another useful feature would be the ability to Sort items within a column. I do not know if either of these are feasible but they would both be desiarable.
