ARCXTPRO - how to do a "TRUNK SEARCH"
llwade
Chillicothe Illinois
using BCD996XT w/ ARCXTPRO software with 10 towers in area. ( I know the tower's Trunk Frequencies )
How do I do a "TRUNK SEARCH" to see who is using the towers?
System is Peoria County, Illinois ETSB (P25) project 25. Harris P25 simulcast system.
I really need a step-by-step instruction. Thank You for your help.
llwade
Default ARCXTPRO - how to do a "TRUNK SEARCH"
you suggested I select " ID SEARCH " mode
are you referring to the ARCXTPRO software or the BCD996XT scanner ?
How do I do this ?
captclint
Mentor
Mountaintop, PA
How do I do this ?
In the scanner: To toggle between ID Scan or ID Search Mode while scanning each trunked system, press
then Scan/Srch. In ARC, click on the system folder, then chose Trunk system parra's. and select " search."
llwade
CAPTCLINT,
in the scanner, I dont know where ID SCAN / ID SEARCH mode is at
in the ARC program, I have no 'SYSTEM FOLDER".
I only have :
file-edit-option-setup-quickkey-internet-scanner-tools-help
llwade
I think I found it.
went to what I was scanning. pressed FUNCTION button, then SCAN/SEARCH button.
it changed from scan to search and I heard a "foreign" station talking.
thank you for taking the time to show me.
