Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 08-19-2014, 3:34 PM
Exclamation FreeSCAN Doesn't Save Comments?
When I create a set of systems on FreeSCAN for my BCD396XT, upload it to the scanner, then download it, the comments on Talk groups are no longer there. How do I keep the comments? Is it possible?
Thanks,
Nick
Old 08-19-2014, 4:52 PM
The comments should be saved when you save the file to the computer. I don't think the scanners have the ability to save the comments.
Old 08-19-2014, 9:32 PM
Blackink's Avatar
I use the Comments section for notes I want to add for frequencies that interest me.
Some frequencies may be on a "search mode" and I'll hear different areas depending on the PL tone my scanner lands on. When that happens, I'll make a note in the comment area to help me remember later.
Steve in Vermont
Uniden BCD325P2, BC125AT
Uniden BCT15X - FreeSCAN - ST2 Antenna by Antennacraft
Old 08-19-2014, 9:44 PM
Wiki Admin Emeritus
Nope. They're only there for that profile (.996 file). They can't be sent to the scanner because there's nowhere to hold them. If you create a new profile, that means new comments
