Freescan and trunking systems
IF you are comfortable with the EZGRAB function, the system you selected in Santiago can easily be setup.First it is a Motorola type 2 p25 so setup the system as that through system selection. First create the system, call it santiago police, then through ezgrab past the frequencies into Freescan. Since no groups are posted in the RR database, set the system as id search. Assisgn a quick ket to the system created. you will then have the system controlled by one key. You can select it or de-select it as desire. A file that can be imported into Freescan I have attached that demonstrates this. You have 4 systems, each assigned a quick key, 0 through 4. On the botton screen of the scanner you will see 0-4. Pressing these buttons will select or turn on or turn off systems as desired. Unfortunately RR does not have group information , maybe you can capture and forward as you find out. File is zipped, you will have to unzip.
