Just started using BC Tool & when I uploaded my 396T to the program all of the frequencies in my scan lists are out of the order they appear in the radio, is this normal for this software or is it going to download in this order, also can't to save any changes using the "save as" drop down, tried putting this in the Uniden forum but for some reason I wasn't allowed.
I'm not sure if this is what you are looking for. When I make a change in BCtool, such as adding a new
system, BCtool doesn't put it in the place I'd like. What I do then, is finish all the changes I want to make
in the software, upload it into the scanner. Then, I download from the scanner into the software and
everything is in a nice, neat order. It seems the scanner will sort everything. It's kind of a pain,
but it makes the database orderly.
Hope that helps.
