You should not have to create the SYS file. As the radio scans, ID Tracker III should build the files and collect frequencies and IDs as it goes. Once ID Tracker has captured the data you can then identify the frequencies and IDs. ID Tracker will then display the data the next time that frequency or ID is hit,
Ok, I uninstalled,removing all traces then re installed, . How long should it take ? Its been running for over 30 minutes. Its only displaying cc freq and voice channels. No id or talk groups. It also, under systems, that lists every one in my radio, is showing a Motorola type 2 system as a conventional system...
This is ths sys file it created .
$Updated=11/22/2014 12:28:13 AM
$SystemName=S C P D
$SystemType=CONV
$Conventional=False
$Selected=True
$Alert=0
$AutoLoad=False
$Timeout=0
$TimeLockout=False
$ScannerLockout=False
$StatusBit=False
$SkipIdentified=False
$SkipEncrypted=False
$TrackSquelch=False
$SeparateAudio=False
$IDLimitMode=False
$LogType=0
$LogMode=0
$MinLogTime=0
$PriorityHold=0
$LogFile=
$DetectAudio=False
$AudioThreshold=1800
$RecordMode=0
$SingleAudio=False
$SpectrumColor=-16711936
!id,flags,hits,description,comments,color,site,CTCSS/DCS,contact
851.36250,1,2,"System Frequency - 851.3625MHz","System Frequency - 851.3625MHz",-16711936,"",,11/22/2014 12:14:18 AM
