safetyobc
Is it possible to load and run programming software on a Windows 8.1 tablet? And then send and receive programming information to and from the tablet to the scanner?
I can tell you that I have no problem running and programming radios from my HP Stream 7 tablet. You just need a USB-OTG adapter which you can get anywhere. As a matter of fact, I'm typing this on my tablet. Setup and programmed Kenwood TH-D72 and BCD536HP. Have a 64gb Samsung sd card in it for extra storage.
Runs anything that you can use on a regular PC. I have Sentinel loaded up, when I'm on the road, hot spot thru my phone and up date the scanner as if I was at home on my desktop.
Bluetooth keyboard connectivity?
Do you find the 7" size to be restricting?
I am using a Stream 8, and without a keyboard, it is tricky to hit the right command. It does support bluetooth, and on Amazon there is a case with keyboard for the 7 inch model for under $40.00. The 7 inch has the same specs as the 8, but the inch more for the 8 does make it a little easier to use. It should be able to handle RR database with supported scanners. The USB otg cable mentioned allows a standard size usb to connect to the micro usb on the tablet.
Now, if I could do that with my PSR-800......
Larry
